Mustang Ac Pressure Switch For R134
Ricardothegreat
Looking for a part number for ac pressure switch. 92 Mustang LX 5.0. I replaced all ac lines and receiver drier with new ones by 4 seasons and added pag oil to convert to 134. My old pressure switch was bad so I couldnt reset it for the different pressure. My problem is that every new switch I can find is either bigger or smaller and wont thread into the receiver drier. Has anybody had this problem and does anybody know a part number for the correct switch? Thanks in advance!
Take a look at the following link:
1979-93 Mustang A/C Accumulators
Unless you have some non-standard things going on (I do not know what you A/C replacement kit requires) then that should be the switch that you need.
Thank you! I will check this out.
@Ricardothegreat
The OEM A/C pressure switch that is located on top of the accumulator has a 1/4" female flare thread that seals with an O ring. If memory serves me correctly, that is a 1/2"x20 thread.
