mustang axles.need awnser quick
94-98 are what you want for a brake conversion on a Fox using SN95 brackets.
99-04 are longer due to a wider housing. Same brake hardware though so if you take the brakes off an '04 GT, you could put them on a Fox only if you use the 94-98 axles
sorry to hijack, but:
can i put 94-98 axles into my fox housing with 94-98 rake hardware and make it all work with the factory parts (not using the northstar brackets)
basically: is the 94-98 housing the same or do i need a new housing?
Yes, it's the same.
A 94-98 8.8 rear end is basically a Fox housing with SN95 brake conversion done to it if you want to dumb it down. Each side is 0.75" wider than a drum-brake Fox
Mustang5L5 said:
Yes, it's the same.
So if you use Fox length axles and SN95 brakes you need the North Carolina brackets?
