Mustang died after hitting bump
We were going out for dinner around 7:00, running down the freeway doing about 70..........hit a medium sized bump in my lane and the car just frikking quits:mad: :nonono: :mad: :mad: :mad: :mad: No warning.....nothing, speedo and tach go to zero and all the warning lights come on.........pulled her onto the side of the road. Pop hood, light on the battery is green, connections are good, all the accessories work and when you go to crank her she wont turn over, but its not a slow crank, its cranking kind of fast. Now she is spending the nite with the local Firestone and hopefully Ill get her back tommorow evening.
Funny thing about that switch, I had my subwoofer slam hard into the sensor box in the trunk and activate the switch. However, it didn't actually cut off the fuel until I stopped moving. I thought that was a very convenient feature as I would have probably been straight into a tree or off in some ditch if my power suddenly cut off.
Then again though thats exactly what sounds like happened to you. I hope the tow truck dude was honest
This sounds like a electrical fault, the gauges dropping out when the car died is a sure indicator of that. When you hit the bump some connection shook loose or shorted to ground. Without being there it's almost impossible for me to know what circuit exactly
Yeah thats what I thought too but then I remembered my gauges did the exact same thing whenever the "cut off" went into effect. I don't think it worked right to be honest.
BTW the switch isn't near the fuel pump, it should be a little button near the left taillight assembly in the trunk.
HMM, the speedo should not shut down when the engine dies but the key is still on.. interesting.. I may have to do a little experiment some night when the highway is deserted near my work.
They called and they have already done electrical diagnostics (no problem there) so now its on to engine diagnostics:(
ENGINE DIAGNOSTICS????????????????? what do they mean by that..
Did you have any noise before this happend or did the car just shut off.
Remember not all techs are created equal in fact most suck ass, so what ever they tell you is wrong you should do a reality check.. let us know on here before you authorize any work.
The car just shut off, they couldnt find anything electrical.......not much I can do since this is my only car, I cant just walk down there and see what they hell they are doing:mad: :mad:
Edit:
Just called Firestone after they said they would call me back, turns out it blew a Maxi fuse???????WTF is a MAXI fuse??????????????????????????
Probably like a Maxi Pad, you need to change them out every month or she'll start raggin on you like she just did. :D
Seriously, I have no clue...hope it's nothing major!
