jcode68
Seems pretty lame to me. You took reasonable measures to ensure the engine was primed, checked the pressure and followed the suggested break-in procedure. In my opinion, you should get to root cause and then figure out what's fair. If the failure happened because of a clogged oil galley or some other engine assembly issue, then I would say the mechanic should eat the whole repair bill. If the root cause is due to something out of his control, like machine shop work, BUT he sub contracted the work to the machine shop, then I think he is still responsible, but should work something out with the machine shop. Unless the problem is caused by something you did, I would expect the mechanic to stand behind all parts and labor assuming he is in the business of building engines and not doing this out of his house on the side. Let us know what the tear down shows.
