Mustang had to be hauled away
I had my 65 289 rebuilt by a good shop but I'm having trouble with it. It fired right up but the valves were making a lot of noise. I didn't want to shut it off until the cam was broke in. After 30 mins I shut it down and pulled the valve covers (maybe a rocker or 2 came off?). Everything looked good, plenty of oil. I started it again and set the timing and rpm. I called the guy who built the motor and he said he did adjust the valves. It has a Comp Cam XE262. I took it to a local shop and they checked all of the electrical and fuel stuff & said it looked good. They couldn't get the valves adjusted either. Said it was misfiring on 2 cylinders and gets really bad above 1700 rpm. Yes the firing order is right (Changed it to the 302 order to just check but still the same)Long story short the guy who built the motor brought a trailer & took it to another mechanic he knows. He said he would do whatever it takes to make it right and he will pay for it. Any ideas??
