Mustang help? Please!
mustang32cobra
I have a 1994 ford mustang cobra. A couple of months ago the rpms started surging and the car cuts out when at idle acceleration and at crusing speed. This is my first car and i can not find out what is wrong with it and i dont have a check engine light on and cant have a test done on it cause i dont have a cadillac converter instead i have a off road h-pipe. I have replaced the fuel filter, spark plugs and wires, mass air flow sensor, O2 sensor, TPS sensor. And i also checked the fuel injectors and fuel pressure and are all working fine. And also all the pressur is normal in the engine. I dont know what to do and my brother is in iraq and cant help me. So please if someone has any advice that can help!
Thank you for your help and your time,
Spencer
Saw your other closed thread. Do you have a K&N filter, and recently cleaned/oiled it? For that matter, do you have an oiled filter? If so, try getting some contact cleaner and spraying the MAF wires. DO NOT touch them. Just spray them clean.
Also, you can still pull codes without the cats. I'm not that familiar with the 94-95, but I know a 93 or older computer can't tell if you pulled the cats. No o2 sensors that far back. Even if it does have 4 oxygen sensors, ignore the codes for rear o2 sensors and see what else you have.
