Mustang squeaking over bumps
yaboy4life93
55
Hey guys, I recently changed all my shocks, which my 01 v6 apparently needed. My orig. shocks weren't too bad, but I am lowering the car, so hey. By the way is 275 good for springs and the camber plates? Anyways the squeaking is from the rear of the car, obviously not from the shocks. I then proceeded to lube everything related to the rear wheels with wd-40. Any ideas of what it may be. It is a faint squeak, but annoying, more so with the dead silence of night. HELPPPPPPPP!
There's only a few places that could be causing a squeak in the rear. It's entirely possible that the new shocks are the culprit, however. It's probably squeaking from a bushing that needs a little chassis grease. WD40 probably won't help.
my front suspention was squeaking out of control, so I switched out the front lower control arm bushings and that fixed my problem. But just check around there for a bushing that should be the problem.
