mustang tilt
You mean you want both a tilt column and an airbag?
I'm not sure that's safe. I'm sure they had a good reason for not keeping the tilt column when they started using airbags...
I won't be replacing the airbags in the car so I won't need to wire anything. If I remember right the column on 89 is round and column on 90 is square? Just wondering how that would look?
it wont fit. if you want tilt there are several people that have swapped a 94/5 column into their car. I am not sure what is involved in the swap so I cant comment on it. It is something that i wanted to do to my 93 for the longest time though.
94+ stuff mounts to the dash itself. the older ones mount to the firewall, dash support. 2 completely different designs. Also there is a bearing in the firewall on the 94+ cars that you need to take into consideration for proper steering control....
Not trying to derail... figured it was useful...
