The car is a pretty much stock 1999 Mustang GT. The other day (thursday I think) it was running perfectly fine when I went to work in the morning, and then after work it would not start. It will start, then revv up real high and die, then the gauges all reset. Sometimes it will idle at ike 15 RPM, and it backfires through the exhaust, but even more through the intake. If I start it and push the gas, nothing happens, unless I go to full throttle, then it revvs, but nothing at part throttle, then dies. It did the same thing when leaving a restaraunt a few days earlier, but then after a while corrected itself and ran fine.
I towed the car to my house so it's not in the way at least, and got to trying to find the problem. I ran a code scanner on it, and only got 2 codes. One for no cats (been that way for years) and one for IAT Sensor Low Impedance. The wire leading to the IAT sensor (the little sensor after the MAF) was broken, and I thought maybe this could be the problem since it's so hellaciously cold out, but it has been broken for a while I THINK. But this morning I fixed that, and the car still won't run.
It sounds almsot exactly like a car with the timing WAY WAY off, but it's all computerized, so how the hell does this happen?? I've ruled out a jumped cam chain, because it wouldn't have happened while the car was off and it wouldn't explain why the problem occured earlier than fixed itself. So it has to be electronic, but with all this computer **** I'm out of stuff I can check.
So, have any of you seen a similiar problem, or have any ideas for stuff I should check?
And here's the longshot question. If I can't find the problem soon, is there anyone out there in Chicago who would lend me a trailer to tow the car to my school so that I can get my teacher to look at it or use different testing tools? When I towed it home I used a rented tow-dolley from U-Haul, but don't care to do that again.
Thanks for any information you may provide...
