http://www.luskvilledragway.com/promos/mustang mainia.htm
Car is for still for sale. Not getting too much luck. Crappy weather is not very helpful either. This might be my last time at the track. Who knows when I'll sell it. So since I plan to go, I had to do a few things. I dont have the Dr's anymore. Kinda sucks cause I knew those tires so well. Now I'll have the MT ET Drags on. But if I run those and launch hard, I could be breaking the rearend which would be not to good right now. So I installed my 31spline carrier and 31spline Superior axles yesterday.
Last week I was able to make the nitrous system work finally. The problem since last year, was that stupid fuel safety pressure switch that was reading false pressures. I checked EVERY component of the system and it came down to this, which I had doubts about. Now it works fine. I cant spray really on the streets because of the cheap tires. So if everything works ok, I should be launching at 4500-5000rpm on slicks with the 100-125-150shot.
I want my 11's
If I dont get it, well It will be my fault as a driver because of my unexperience with the slicks.
Whos coming ?
I want my 11's
Whos coming ?
And I usually ice the upper intake when its that hot but I totally forgot it yesterday. Didnt bring the ziplock bags. I decide to go do my first run on motor only. I have my slicks at 13psi. I'm very nervous at this point. Really have no clue how it's gonna be with the slicks. Drop the clutch at 5000rpm
and it hooks like a mofo. Hooks too much even that it makes me bug kinda. Was 1.67 60ft for that one. EASY shifting and got 12.82@106. The car with the slicks was totally stable. That was a huge relief. And again, lifts the driver wheel off the ground.
Remember that my previous best is 12.801@108mph. So I didnt think much of it. Do it again but with 2 more psi of fuel pressure and 1 less psi in slicks. Dropped again at 5000 but this time bugged me way too much and got 12.9 Next run a drop the clutch at 5600-5700 and hooked like crazy and got a 1.61 60ft and got 12.76@106mph. New best. I was happy but I feel like I dont know what I'm doing up there with the slicks. I dont think I have enough gear for the slicks on motor. There were also a bunch of ricers spreading water on the track with the fwd cars. I did a couple more passes but nothing that interesting. So if I did a 12.7 with that weather and first time out with the slicks, I'm sure if I go again I'll see 12.5's or so.
