danny04GT said:My wifes Mitsubishi used to smell real musty when you use the A/C. Went the Mitsubishi dealership and they sold me "Frigi-Fresh". you turn on the A/C full blast and spray it into the air intake for the A/C (next to the windshild wipers). That kills all the mildew. The bottle was like $5
WillDuhhBeast said:I'd imagine to prevent it, you should leave your A/C recirculate button on before you turn the car off.
sgarlic said:Mine has smelled a little mildewy since I bought the car.. where is the drain hole? I'd like to get up there and check it out.. I think I'll try the Lysol thing too.
Karman's right on the money. The odour problem is worse in humid climates, like where I live. I've got a '92 Safari that I've owned since new, and let the fan run on high to dry the evaporatore core, and have no problems with odour.karman said:Good imagination, I see your point. You want to keep the "bad air" out of the system when you park it. Actually the "bad air" is already in there. It is the mildew that grows on the A/C evaporator core. If you shut off the A/C, put the fan on high for the last few miles before you park it will dry off the core and the mildew will not have a place to grow. It grows in the left over moisture on the core and the drip pan underneath. If you're drip pan drain hole is clogged (and they often do) nothing will help the smell until you clear it out (a good blast of air up the drain tube quite often will clear it). Once you have "the smell" you will need some type of germ killer to make it go away. I've used scented Lysol in the past. I like to roll the windows down before I spray into the cowl intakes beacuse I'm only trying to make the A/C smell better. On an older car, do it like AdRock said and de-odorize everything.
2000GTNY said:The sprays do work well, and I always keep my setting to "Vent" when the car is parked. It actaully says to do this in the owner's manual of my Escape.
