After searching the internet and realizing that the hazards and the turn signal flasher are different that finally made sense since I had replaced the hazard. Now the hard part was finding the turn signal flasher, in the manual for 87-up it says above fuse panel and below the instrument cluster cover or behind radio. So the first thing I did was pull the low instrument cluster cover out and the shield and no dice... So then I was like ehhhh, lets just turn it on and find it, so I looked for where the sound was coming from and I ended up stetching over the front seat into the passenger seat (because I had it parked up against some bushes so I had clearance on the drivers side), and went behind were the A/C unit and radio would be and I happened to pull the right thing and sure enough there was MR. Flasher. So I pulled it off and luckily I had kept my old one that I had taken of my hazards, plugged it in and BLINK, BLINK, BLINK, BLINK! That was the fastest it ever had blinked, like 3 in a second, im used to 1 in three seconds or even more! Thank you guys for the help, BTW the manual sucks it left me hanging after its vague descriptions of where to look, no diagrams. JEASE FUQING MANUALS.
