My Car died leaving me stranded
'95GT5.0
10
My car died on the highway the other day. Just stopped dead in its tracks and never would restart. With the key on, every thing works but the fuel pump and the fan. I just did a complete h/c/i installation. The car ran great after I got the tweecer hooked up. I did some posting on other websites, and I was refered here for information on a ccrm. I cant find anything on it. Does any one have any ideas or suggestions. My car is a 1995 gt, 5 spd, trickflow street pacakge; heads, cam, intake, 70mm tb, 200 amp alt, 180* therm., stock injectors and maf, I also have been playing with the tweecer and most major issues "tweeced" out of my computer.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
88Stang331 said:
Richker i am positive now that you have to have that stuff saved in a word document. :rolleyes:
That one and about 347 other answers. Pepole keep asking the same questions. I keep updating the saved files with new information as I learn more and new problems arise.
[QUOTE='95GT5.0]My car died on the highway the other day. Just stopped dead in its tracks and never would restart. With the key on, every thing works but the fuel pump and the fan. I just did a complete h/c/i installation. The car ran great after I got the tweecer hooked up. I did some posting on other websites, and I was refered here for information on a ccrm. I cant find anything on it. Does any one have any ideas or suggestions. My car is a 1995 gt, 5 spd, trickflow street pacakge; heads, cam, intake, 70mm tb, 200 amp alt, 180* therm., stock injectors and maf, I also have been playing with the tweecer and most major issues "tweeced" out of my computer.[/QUOTE]
You are on the right track, me-thinks. The fuel pump and high and low speed fan relays are in the CCRM. It can be worth checking the power pins to the CCRM to make sure they're ok.
When the car is up to temp (210* or above, per the stock sender location), you can put your meter on Pin 14 of the CCRM and look for 12 volts.
Or turn the MAX AC on and check Pin 17 of the CCRM for continuity to ground. If you have these inputs but no fan, and you have power to the CCRM (equivalent to power to the common terminal on an SPDT relay), the CCRM is possibly bad.
Good luck.
I forgot to say above to check all fuses (underhood fusebox and interior box).
Forgot about the fuel pump too. Check the inertia switch that JR mentions.
Look for power at CCRM Pin 5 and 11 for the fuel pump relay.
dragnazz5.0 said:
you should just make a website with all the files on it...that way you dont have to use up the space on your computer and it can be a sticky in the forums
I have 60 GB left on a 74 GB hard drive...Lots of room to create more tech docs. :D
[QUOTE='95GT5.0] Where is this CCRM located, and what does it look like? I'll try that first.[/QUOTE]
Find your overflow bottle in the engine compartment (pass side, adjacent the radiator). The black box attached to it with about 40 wires going into it is the CCRM. If you look real close at the connector, you can see the numbers for the pins.
When you pull KOEO codes, the fan will cycle low and high speed - pay attention for that (it does it first thing upon starting the retrieval process).
Good luck.
