  • SN95 4.6L Mustang Tech
MY CAR WON'T START, PLEASE HELP!!!
  • Thread starter Thread starter niminum
  • Start date Start date Jan 9, 2008
N
niminum
  • Jan 9, 2008
I just finished installing my new Accufab upper intake plenum/throttlebody combo on my 2000 GT and now my car wont even crank. before the installation i disconnected the negative on the battery and when i try to start it my theft light flashes. i have the factory anti-theft alarm, could somebody please please help i'm desperate to get it started before i have to go to work. and advice is greatly appreciated
Airbeast
22
Johnson City, TN
Jan 9, 2008
  • Jan 9, 2008
Is the battery cable the only thing you disconnected? Did you disconnect the big wiring harness connector? Also, I had ended up with water in my ECU connector(inside the car) I was causing all sorts of craziness including the theft light and no starting.
98E9GT
110
  • Jan 9, 2008
What about disconnecting the battery neg terminal for 15 minutes and put it back on and see what happens. Helped me out.
2000fordstanggt
404
Westland, MI
Jan 9, 2008
  • Jan 9, 2008
better yet, take them both off and touch the pos and neg together to discharge anything left in the system.
2002GreyGT
481
Raleigh, NC
Jan 11, 2008
  • Jan 11, 2008
Try a differnet key, maybe the ECM lost the info on the key you are using since they have the chips in them...
~K
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jan 12, 2008
  • Jan 12, 2008
Are you the first owner of the car ? If not are you 100% sure there wasn't a dealer installed aftermarket alarm in your car ? Some alarms will cause the car not to start if they loose battery power. They come back on in an armed possition and you have to turn them off with a remote to get the car to start. Look under the dash on the drivers side. These things are hard to see some times. They are usually little black boxes with a bunch of wires spliced into the factory harness. If you do find one, get all the numbers you can off of the box and buy a transmitter for the box. Or you can try and remove it but some surgery is going to be in order for the harness and working under that dash is a royal pain.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
H
2010, 4.0 no crank no start
  • htmlngnstrt
  • May 21, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 22, 2025
89ripper
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
