I hate those "periods" when everything breaks at the same time or so. On my Cutlass, I had a flat 2 days ago. It was a 1in. screw completely in my rear tire. The Cutlass has been having a "tiny" leak of gas from the tank. You cant even see leaking but you sure can smell it. This morning, as I was picking my suit for my GF's graduation on Friday, I noticed a spot of liquid under the car as I was walking back to the car. COOLANT. Its not the rad, not the hoses. Most likely the water pump..
On the stang, I had that shortcircuit a few days ago that I solved but now I got some problems with the alarm. I dont know what happened but I know its related to that shortcircuit. Sometimes, It will completely stop me from starting the car. Its not even cranking. I'm not even sure if my battery is still good, again because of that electrical problem. The T5 is leaking. I noticed it for a few weeks now but didnt think much of it. Does not appear to be the 2 plugs. Its like there's not enough silicone at one particular place, where 2 pieces bolt together. I still have to fix that thermostat housing. On my chrome one, there's a screw on top. It needed Teflon. I need to go put some shortly. Its not really leaking. On my way back from the meeting yesterday, the LOW COOLANT light appeared. But the coolant is fine. Maybe there's air stuck in the system, because of that screw from the housing. The Air bag light has been on since we put the engine back in the stang. I dont know what this is all about.
Cars..
Cars..
