I'd like to start off by thanking everyone at DynoSpeed Racing and MT!!
So I drove 150 miles to Dyno Speed Racing located in Memphis, TN to run on their Dynojet and get a tune from an SCT Xcalibrator 2. When we got there we did a pull in 4th gear and the car put down 257.49 HP and 284.81 TQ and the A/F line was right below 15 (ouch!). We they loaded up the tune through the Xcal 2 and the car cooled and we were ready for the next run. When he shifted to 4th it acted like there was no 4th gear, the car didnt respond to it at all. It would let you shift into 4th but you could have the pedal all the way down and nothing. So they talked to SCT, messed around with the tune, and tried again. Same results. So they loaded the stock tune, even worse results. Thankfully it threw a code and it was traced back to the TPS (I knew that thing would cause me problems). It was bad so we ran to Ford to pick up another and all was well again. The final run put down 270.77 HP and 306.68 TQ. I'm happy with the numbers because I predicted 270, A/F was right around 13. Attached is the dyno graph and a pic of my car
The blue lines are from the first run with the stock tune, red is with SCT Xcal 2 tune. All mods are listed in my sig.
here is the stock run video: clicky
here's what your car sounds like when 4th gear doesn't work
: clicky 2
Thats what their add says anyway.
Adding gears to what you have now will make one pissed pony.
