  • SN95 4.6L Mustang Tech
my engine cut off when driving...
  • Thread starter Thread starter juniordelor
  • Start date Start date Feb 6, 2008
J
juniordelor
11
fl
Feb 6, 2008
  • Feb 6, 2008
Hi everyone, to get to the point this morning i was driving to work and i was about to make a right to enter a parking lot suddenly the car just buckle up: engine cut off, the steering wheel locked up, i push the brake car keep sliding, when it finally came to a stop, i saw the "service engine soon" light on, i turn the ignition off and back on the car started with no problem. Thank God there were no other cars in the lot, it was early; it could have been ugly if it happened 45 minute later.
So, has any of you experience this problem before? and what do you guys think might be the problem,? i called my ford dealer they told me to bring the car in. my car is a 1999 mustang gt, 5 speed bone stock except i replace the plastic intake manifold with the new aluminium crossoever one.
2000fordstanggt
404
Westland, MI
Feb 6, 2008
  • Feb 6, 2008
my first guess would be the fuel pump.
saleen556
387
Hillsboro,OR
Feb 6, 2008
  • Feb 6, 2008
Mine was doing that a few months ago. I swapped out the FPDM and fuel rail pressure sensor and it never did it again. My fuel pressure would drop just before it would die though.
Lasik12
Panama City, FL... for now
Feb 7, 2008
  • Feb 7, 2008
Might also want to check your MAF sensor and wiring.
2002GreyGT
481
Raleigh, NC
Feb 8, 2008
  • Feb 8, 2008
Mine had done that 3-4 times in the past 5 years, usually when making right turns. Never really figured it out.
However, my RPMs where dropping when I would take it out of gear and I found a small crack in my PCV hose and fixed that and the problem went away.
~K
M
MichaelsLilGray
32
Tyler, Texas
Feb 8, 2008
  • Feb 8, 2008
Check all your vaccum lines and your filter. It sounds like you have a air leak.. and a bad one at that. Get some MAF sensor cleaner. Clean it off, and try it again. It could have been any of these problems.. good luck on it
forum155pl
520
the 509
Feb 8, 2008
  • Feb 8, 2008
could be a bad battery connection..
BurningRubber
1,865
24
58
Feb 8, 2008
  • Feb 8, 2008
A bad or dirty IAC will cause it to dip in idle sometimes and stall out. Happend to me alot.
blckstng96
208
  • Feb 9, 2008
could be a number of things,fuel pump is a good candidate,maybe a faulty crank sensor,fuel pressure regulator.mine does something similar but it only does it when the car is low on gas around a quarter tank and it has a wierd starting problem after i fill up.i usually prime it a couple times and it works better.idk,odd problem.
eliteJAE
Stanford University
Feb 9, 2008
#10
  • Feb 9, 2008
  • #10
+1 on vac hoses, mine would do this after WOT runs or slowing down to exit the freeway, the rpms would just fall and fall and fall til it died lol i figured it was a vac leak cuz i tightened all my hoses and it never happened again does the CEL turn off when u restart it??
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
