my first time at the track
bboylobo
130
Lancaster PA
Ok guys, ill be running my 01 gt for the first time on the track. thisll be the first time i ever ran on a track:Track:. i had some questions for you pros out there
what are some things that i should be aware of when i get there?
How can i not look like a super noob? :rlaugh:
i have a 5 speed, and i was wondering how to figure out my shifting. I dont know too much about shifting other than what i do to get around. Is there a difference in shifting on the track? Do i keep the gas floored the entire run?:shrug:
Thanks guys ill fill you in when i run. BTW i have 3.73s and a CAI if that has anything to do with my shifting
:SNSign:
i know how you feel, i had my liscence for 2 week and i was at the track looking like a idoit:rlaugh: you will want to shift around 5800-6000k, with those 373's you gonna have to slip the clucht off the line, or you will spin terrible, give it a few runs and you get the feel of it:nice:
Oh yeah... and its alot harder then it looks:(
I'd say more between 56-5800 RPM for shifting. 6k is overkill on a basically stock 4.6, even PI.
Launch easy just to get the hang of it.
If you arent framiliar with shifting hard and fast, don't go all out on your first few runs because you will probaly miss/grind a few gears and really slow yourself down.
When you get there, go up and watch some other cars run this way you can get an idea where the staging lanes are and check out how the tree works.
If youre running street tires do not go through/back into the water box, instead do a quick spin to get any debris off the rear tires. Dont worry about youre reaction time as it has nothing to do with ET's, instead focus on youre launch.
I try to shift just under 6K, thats where my best times have been.
Where are you located? My advice is to get there a bit early, and while allowing the car to cool down, watch the other cars.
With street tires, you'll want to avoid the water, though if that isn't possible just roll through it and do a SMALL spin just to get the water off. There is no need to sit there and smoke the tires since that will do NOTHING for you on regular tires other than waste rubber. Watch how the other cars prestage, then stage. Also pay attention to where they are turning off the track as that will give you an idea how fast you will need to slow down.
i wouldnt run powershift at all for your first few runs. First run just get the feel for how the staging process goes, dont push it too hard. After you feel comfortable with that then launch probably around 1300-1500 if you dump it and spin you know for the next run to slip the clutch. It's all in feel for the car and knowing how to drive it... that's where the best time are.
And like people above me said, reaction times do not help with ET at all! worry with getting a good consistent launch that doesnt spin too much and also doesnt bog you down. once you can consistently launch like that then worry about trying to cut a good light. You can drop the tire pressure down to 25-30 for a little better traction... oh... and to make yourself look super noob leave the TC on :D always turn that sucker off.
