my major help me thread of 5 lug.
  • Thread starter Thread starter fivespeedsteed
  • Start date Start date Sep 4, 2008
First Prev 2 of 2
1990Coupe
1,462
132
114
Toms River NJ
Sep 5, 2008
#21
  • Sep 5, 2008
  • #21
fivespeedsteed said:
oh yeah i guess your right that would push the drums off the shoes if it was wider. so if i stay with drums i basically have to stay fox length. so it wont look strange with a wider than stock track up front and stock track in the rear?
You'll HARDLY notice.. Look at SVT32V's black notch you can't even tell.
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 6, 2008
#22
  • Sep 6, 2008
  • #22
and by having the wheels not sucked in that much will be easier to clear everything right?
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 6, 2008
#23
  • Sep 6, 2008
  • #23
so the setup is ranger axles, 5 lug drums, 94-95 spindles, sn-95 balljoints, and buy new 99gt or v6 brake calipers, get the core though advance ( i work there, wont be a problem) and then 99 + rotors?
5.0Torx
252
Sep 7, 2008
#24
  • Sep 7, 2008
  • #24
right on except i beleive 94-04 non cobra rotors are all the same. my PBRs fit over my 95 gt rotors that i got when i bought the whole shabang off ebay.
oh yeah, one last note, i did have to do SLIGHT grinding to my 95 spindles to get the PBRs on. Dunno what the deal is with that and you may not have the same problem at all, but be aware of it. im sure others didnt. im running abs spindles. non-abs spindles might not have the same issues. i dunno!
Mustang5L5
Mod Dude
Feb 18, 2001
43,309
18,021
224
Massachusetts
Sep 7, 2008
#25
  • Sep 7, 2008
  • #25
The FOrd 99-04 rotors are slightly better quality than the previous 94-98 rotors. They are physically the same 10.8" rotor, but the quality is different.
If you go out and buy aftermarket or parts store rotors, i'm sure they are all the same. Even the new 99-04 rotors probably cross-reference back to the older 94-98 cars now anyway...so it's a moot point unless you go out and buy used rotors off a 94-98
To fit the 99+ Gt/v6 pbr's, you'll need to grind the spindle slightly to fit the pistons of the caliper. You'll see it when you try to mount the caliper up. Not a big deal..and not a whole lot of grinding
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 7, 2008
#26
  • Sep 7, 2008
  • #26
yeah my thread on corral, people are telling me to go with 96+ spindles so i dont have to grind. cant get a good idea on what is required to get those to work though tie rod wise. id rather have the newer ones. they have better ackerin right?
Mustang5L5
Mod Dude
Feb 18, 2001
43,309
18,021
224
Massachusetts
Sep 7, 2008
#27
  • Sep 7, 2008
  • #27
yes, they are much better overall and can be had cheaper. But depending on what wheels you want to run, hey may stick out.
Upside is 96+ tend to sell cheaper than 94-95.
I've been debating ditching my 94-95 spindles for some 96+ units. I want to run S197 wheels, so the extra width is needed anyway
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 7, 2008
#28
  • Sep 7, 2008
  • #28
well mm website says not to use 96+ spindles because it screws up the gemetry. so ima go with 94-95 spindles and have to grind them a little. now for balljoints if i upgrade to sn95 balljoints do i need spacers?
5.0Torx
252
Sep 7, 2008
#29
  • Sep 7, 2008
  • #29
you mean the spacer to get the cotter pin to line up? if so, no, and thats the point in getting an SN95 BJ rather than a fox BJ. in fact, when i bought my SN95 BJ, it didnt even use a cotter pin. it used a nylon lock nut. easy!
First Prev 2 of 2
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
