In a nutshell, it'll cost about $500 more for a 351W. I know the 347 will be faster because of rotating mass, but I'm looking for the reliability and growing room of a 351. Here's my breakdown, am I missing anything?
351W
Oil pump $35
Oil shaft $15
Oil Pan $145
GT40 Lower $309
351 balancer $189
ARP Studs $139
Swap Headers $289
Pushrods $85
Distributor $189
Dist Gear $35
Gaskets $159
Timing Chain $69
Plug Wires $69
Oil/Coolant $45
Engine $175
Flywheel $300
Roller Conversion $400
Drop Mounts (Modified K) $150
75mm TB $150
Machining
Hot Tank/Magnaflux $130
Bore $165
Align Hone $120
Balance $175
Cam Bearings Install $20
Deck $50
FTI Cam $325
AFR 185 Heads $1500
Forged flat top pistons $300
$5732
Forged 347 Stroker in Stock Block
Pan $100 (current one is broke)
Edelbrock RPM II Intake $350
Studs $139
1 3/4 Longtube headers $250
Pushrods $85
Gaskets $85
Oil/Coolant $45
70mm Throttle body $150
Machining
Hot tank and check $130
Bore w/ girdle $245
Align Hone $120
Balance $175
Cam Bearings Installed $20
Deck $50
FTI Cam $325
AFR 185 $1500
Stroker Kit $1300
Girdle $200
$5269
How durable are the stock 351W rods and crank?
351W
Oil pump $35
Oil shaft $15
Oil Pan $145
GT40 Lower $309
351 balancer $189
ARP Studs $139
Swap Headers $289
Pushrods $85
Distributor $189
Dist Gear $35
Gaskets $159
Timing Chain $69
Plug Wires $69
Oil/Coolant $45
Engine $175
Flywheel $300
75mm TB $150
Machining
Bore $165
Align Hone $120
Balance $175
Deck $50
FTI Cam $325
AFR 185 Heads $1500
$5732
Studs $139
Pushrods $85
Gaskets $85
Oil/Coolant $45
Machining
Bore w/ girdle $245
Align Hone $120
Balance $175
Deck $50
FTI Cam $325
AFR 185 $1500
Stroker Kit $1300
Girdle $200
$5269
