My Roller Bearing Pedal Assembly
gp001
4,401
So. Cal.
I posted a thread a little while back asking about other setups. Well, here is what I came up with :D
All the details can be found here:
http://www.2mfffabshop.com/pdlasy.htm
mustang70 said:
Looks good. For those running a power brake pedal should there be a tube or something in the pedal hangar to help support the bearings?
Did you get my pm?
I will admit that I have never seen a 70 pedal assembly, but don't you have a shaft on it now going through the pot medal bushings?
When did you send a PM? The last ones I got were from Gram on the 15th and the 13th.
The shaft the the clutch runs on goes through the hanger and the brake pedal rides on it's own shaft.
I sent the pm early last week. I think the storm may have caused problems. I sent one to Foggy too and I know he didn't get it.
okay time for the stupid question to come out.... I see one pedal, where are the gas and clutch? do they ride in the same rod or different rods?
reason I ask is I converted to stick from auto a few years back and thought it was a single rod that held all together.
just curious. Thanks!!
The gas pedal is a separate deal altogether. The shaft that goes through the center of the pedal hanger is actually attached to the clutch pedal arm. The brake pedal arm rides on that shaft in the center of the pedal hanger.
dolfan87 said:
GP...can you pm me the total man. I lost a bunch of PM's this weekend, and I need to know how much to send you.
I would pm you, but I am afraid it wouldn't arrive. ;)
87
I completely forgot to PM you. SN was down the day I sent the stuff to you. I do it tomorrow.
