My setup Help
  • Thread starter Thread starter snoboardcore
  • Start date Start date Dec 5, 2006
snoboardcore
276
New Hampshire
Dec 5, 2006
  • Dec 5, 2006
Ok im going to be building a 331 forged internals all that jazz with a compression ratio of 8.5-1 and 15lbs of boost from my s-trim for right now.
Im thinking of going with one of the XFI comp cams or keeping my Wolverine 1190 cam, AFR185 heads, but on the intake im not to sure. Im not looking to rev the car high only around 6k. MY gt-40 pulls real nice up to 5,800 but every chart i look at the gt-40 was making more power than the sytemax 2, victor 5.0, and the tfs-r up till 5800. Are there better intakes that will make more power up to 6k. I know its a silly question but these numbers where on a 347.
JBeezy53
559
Sacramento, Ca
Dec 5, 2006
  • Dec 5, 2006
I would go with the Eddy RPM II, but that will probably make power past 6000.
soontobefastfox
275
Troy, Michigan
Dec 5, 2006
  • Dec 5, 2006
systemax II
strker347
44
  • Dec 5, 2006
I would go custom cam from Cam Motion, FTI or Jay Allen. Port matched Holley Systemax ll or TFS-R and port matched AFR 185 heads. The AFR 205's or TFS Track Heat 205's would even better on ur 331 because it is boosted. The TFS R intake pulls from 2500-7500.
I would also use a Probe dish piston (14.2) to get around 9:1.
Remember keep ur rotating assembly light to spin up fast. Lightweight 4340 I beam rods w ARP 7/16" rod bolt upgrade, Romac ultralight 28oz damper and Fidenza 28oz aluminum flywheel.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
new edge coolant leak need advice asap
  • 2vBoogs
  • Tuesday at 8:37 PM
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:38 PM
Mustang5L5
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
