My stang died after an hour drive!?!?!
red92five0
Albuquerque
I live in NM and I was taking a drive from Albuquerque to Santa Fe (about a 45 min drive) and when I pulled off the highway, my car started to feel strange. After the light changed, I turned and my car sputtered and died on me and wouldn't start up again. I opened the gas cap and gas started to FLOW out of the filler hole! If anyone knows what it could be, I would love the advice.
I can't explain the gas overflow problem (did you get really good mileage maybe? kidding...). The first thing I would suspect after a long drive (and probably a lot of heat soak) would be the TFI ignition module on the distributor.
+1 vote for the TFI.
Fill up a car with cold gas from and underground tank - the gas volume will be at a minimum because it is colder than the surrounding air. Drive the car and the gas heats up because the excess fuel volume returns to the fuel tank courtesy of the fuel pressure regulator. Drive the car in the Albuquerque to Santa Fe area and the gas really heats up. As it heats up, it expands. Take the cap off and if its still full, it will boil over like a hot radiator. Check the carbon canister vapor recycle system while you are looking at things.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 05-Aug-2010 to add check for distributor timing in paragraph 6C.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
I forgot to add one qualifier, did the car start back up after everything cooled off ? If not, then it might not be the TFI (it should cool off and recover until next time). Otherwise your fuel pump may have choked on you or one of several of the other things mentioned in jrichker's check list.
I have replaced the fuel filter and TFI module not too long ago. The car does start up after it cools down. I can drive around town without any problems and I haven't had a long drive since then.
Silly question, but did you apply plenty of the heat sink compound to the back of the TFI module when you installed it? It helps dissapate the heat the module produces, very similar to the processor in a computer.
If you are smelling gasoline, pull the vaccum line off of the FP regulator and see if it's sucking gas through the diaphram. Also check to make sure you are not leaking gas around the injectors or from a fuel pressure gauge if you have one.
It sounds like your gas tank cannot vent the fuel vapors when they expand on a hot day, and those vapors might be getting pumped into the fuel lines causing a vapor lock. Check the vent tube from the tank to the charcoal canister for any blockage. The purge valve near the charcoal canister could be stuck closed or the filter inside the canister itself could be clogged.
I made sure to put a nice even coat of that thermal compound on the TFI module. I've checked for leaks and haven't found any. What would be the best way to check the purge valve besides driving around and popping the hose off? Also, has anyone ever heard of tossing the canister in the oven at a low temperature to "recharge" it. I've talked to a few people that have done it but I'm just a little uneasy about doing that.
What I meant was after the cars cools off in your driveway, pop the vacuum hose off of the fuel pressure regulator on the passenger's side fuel rail and check for fuel inside the hose. Also you might want to consider buying a fuel pressure gauge that fits in the fuel rail Shrader valve so you can see exactly what your fuel pressure is doing at the time your are having your stalling problem. If you can rule out fuel pressure problems then you can move on to other efforts.
I wouldn't put anything possibly flamable in my oven. I would probably remove the canister first.
Sorry for not clarifying, my car runs (haven't had any problems using it as my daily driver). However, I don't want to take another drive out of town and be SOL on the side of the road and I figured that it was more than some freak occurence so the problem is still there. I purchased a pressure gauge and I'm going to toss it on after work.
Sorry about taking so long to reply, I've been super busy. It turns out that purge valve was bad. I got a replacement from napa for $60. Feels to be running better but I'm not sure if I just feel that way because I know I replaced it. Hopefully, all is well now.
Similar issue
I followed the checklist on this thread, and am a bit stuck @ this point. I also have a 92 LX 5.0. The car was running along just fine then out of the blue, died and has not restarted since. I have good spark, because if i spray ether in it will run for about 5 seconds before it runs out of fuel and dies, tested fuel pressure to the rail and pressure is good. Things I have noticed are that with the ignition on, the fuel pump never stops priming, and when trying to crank the car, a Noid light installed on 1 of my injector wires gives no light at all. Is it likely that the problem is the PIP sensor even if I am getting spark? Was recommended to me to replace the TFI, but if the TFI was bad, I would expect no spark, not no injection functionality. Any input would be greatly appreciated. Already have replaced parts that weren't the issue, and with the weather getting nicer, I really want to get this monster back on the road! Thanks in advance!
