My Xenon HID conversion is finally finished! *PICS* Didnt cost me a penny ;)
yeppp mine are 8000 now.. lose light or not, these 8000's are MUCH brighter then them hiperwhite xenon bulbs... my brother has them 12000 purple ones in his yukon.. looks real sharp and visability is awesome!
mine...
Sorry to hijack the thread
K has nothing to do with brightness of the lights. It's just the color of the light. 18000K is just as bright as 5000K.
I want white light, no color at all. WHite = clean and pure and that's the look i want for my GT. Blue or purple lights don't really look good to me.
I kinda like Meccatune's HID's so i might go with their 6500K kit.
Mike, to my knowledge 4100k is the most desireable amongst the hardcore HID crowd. And like I said, blue causes eye fatigue over time. Just some things to think about. I'm planning on doing a retrofit with projectors in my stock headlamps.
Here's a page i found that shows the color differences
i myself prefer the 4300k on that graphic
http://www.hidexpress.com/
Now i'm just researching which brand to get.
1 question though. Say i get a 9007 retrofit kit and put it in my '03. If i sell the car later, can i buy a 9004 bulb, and plug it into the original ballast so i can run it in my fox? Will the bulbs interchange between ballast kits like that??
Gotta do my research before Xmas...i think i'm gonna ask for this from my parents....meaning i gotta order them myself because they have no clue :)
What's with these kits guys? I don't see any ballast. Is this a gimmick to suck you in that doesn't provide all the necessary pieces?
Diamond cut Sealed Beam conversion kit
This set is complete it includes: 2 DOT approved Diamond cut Sealed beam conversion housings, 2 wiring harnesses, 2 rubber covers (keep housings dry), 2 65/55 Standard Wattage Xenon H4 bulbs that have an output of 90/100W. These are for the low beams only, email me for high beam info
BlackFox5.0 said:
:lol: Those are halogen. HID are around 35watts.
I just bought some Phillips 4300k D2S HID Bulbs on ebay :) One step closer.
Yup, HID bulbs are totally different. And Xenon is a brand, not a type of light...just like the whole NOS/nitrous thing.
You'd be surprised how many people think a true HID conversion just needs bulbs. I tell friends the price and someone always chimes in "It's not $400, i paid $29.99 for my bulbs"
Not the same thing :bang:
STANG5T5----fyi a 9004 and a 9007 bulb are the same thing turned 90 degrees... so if you swao bulbs you will project to the left and right your brights will be even wider so unless the kit turned how the bulb is oriented then it wont work a 9004 and a 9007 are not interchangable
I'm not sure if you were trying, but that didn't really answer my question. :shrug:
anyone else with some input. I want to get some HID's now.
DO NOT PUT HIDs IN A STOCK HALOGEN REFLECTOR HOUSING! The light outputted from an HID bulb does not scatter properly when installed in a halogen reflector housing. It causes a lot of unwanted glare to oncoming drivers.
The proper way to put HID's on a car is to retrofit a pair of projectors into the stock housing. This way, you get the same light output as an audi or bmw and you don't cause any glare to oncoming drivers. A properly aimed set of HID projectors will cause less glare than a set of halogen reflector housings while providing muuuuch better light output.
I have a pair of BMW e46 bi-xenon projectors in my car. These projectors allow me to have both high and low beams. I'm in the process of redoing the retrofit right now so I will be making a write-up on how to install them in a set of fox body housings.
