  • 2005 - 2009 Specific Tech
Mycolor for those without the harness
  • Thread starter Thread starter Deric
  • Start date Start date Apr 7, 2009
Deric
23
  • Apr 7, 2009
I was looking over the schematics for the message center switch and they are wired directly to the instrument cluster except for one wire that goes to the SJB for illumination. If you are the hack/mod type you should be able to make your own harness. Another option is to go to a bone yard and get the harness. I've had one person so far try this with success. You do have to splice into the ground wire and according to the schematic there is a splice point at S201 or you could tie into another ground. I already have mycolor so I didn't have to do this mod but thought there might be others who want to do this mod.
Parts provided by Kevin Casey and other members
PigTail connector: Motorcraft Part # WPT-554
Info/Setup/Reset: Ford Part # 4r3z10d889aaa or 6r3z18578aa
Pins to plug into Inst Cluster/SJB: ???????
Mycolor/GT500 Clusters: Check with your local dealer
The schematic PDF is 150k so since it is outside the posting limit here's a link.
Schematic PDF with Connector Layout
08blueskunk
217
Maine
Apr 7, 2009
  • Apr 7, 2009
I get employee cost on the gauges and switch, and it goes for less than $300 total...here is the info i got...
"The part number for the cluster is 7R3Z-10849-GB
Switch is part number 4R3Z-10D889-AAA
You will need to take it to a dealer to get it flashed or it will beep at you when you go over 70 MPH. Thank you, Kenny"
R
Randy 25
101
  • Apr 7, 2009
I had mine upgraded to the 4 gauge/my color by a Ford dealership and it cost me $458 total, parts and labor. Works perfect. (I had the pigtale behind the dummy switch plate.) I mostly did it for the other two gauges and the message center, the My Color was a little icing on the cake. Glad I did it.
Deric
23
  • Apr 7, 2009
Yeah several people have the harness but if you don't have traction control you may be out of luck. I thought I would post so people who don't have the harness know there's an option for them. It takes a bit of work but if someone wanted it bad enough it's still not too bad. I personally have thought about upgrading to the GT500 cluster just because I wish the speedo and tach were swapped on mine. The non-working boost gauge is the only thing keeping me from it.
  • dan50
  • Jul 18, 2026
dan50
Engine Ron Francis aka The Detail Zone and their Ford harnesses are beyond poor quality.Here's why.
  • CAMTWO1070
  • Oct 20, 2022
5K
Fox 5.0 Mustang Tech Nov 13, 2022
CAMTWO1070
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
Engine New to Mustangs, guidance needed on fault codes 47 & 45
  • sUdz6.0pwrstk
  • Sep 30, 2021
5K
Fox 5.0 Mustang Tech Oct 23, 2021
General karthief
01 v6 very dash wiring issue
  • Sisbell-2003-3.8l-V6
  • Mar 10, 2020
  • SN95 V6 Mustang Tech
2K
SN95 V6 Mustang Tech Mar 25, 2020
wmburns
