I have been trying to fix an oil leak on my 289 that has puzzled me for weeks. The leak is originating in the front of the motor in the vicinity of the oil sending unit, fuel pump, and oil filter area.
The leak only occurs under high rpms/higher pressure, usually when I driving under “extreme conditions.” Over the weeks I have replaced and/or cleaned the following:
oil filter
oil pan gasket
oil pressure unit and extension
There are no visible signs of leakage from the fuel pump to timing chain cover gasket, oil pressure unit and extension. The hard part about this is when it goes it sprays oil over everything in the vicinity, even upwards on the back-side of the power steering pump bracket.
I know it seems far fetch, but I am now looking at the fuel pump as the problem??? I know the fuel pump has access to engine oil through the timing chain cover, but it there enough pressure and oil that would cause this under high rpms. Second-guess, oil filter even though this is the second filter having the same problems as before. Has anyone experienced a similar situation or have other ideas?
oil filter
oil pan gasket
