Tim65GT said:Sorry I did not catch this post the first time.
I had this EXACT problem before. I replaced the filter and the oil pressure sending unit extension making sure it was tight and sealed with teflon tape.
Nothing I did helpeduntil one day I revved it up while looking carefully at the area right in front of the oil filter. It was getting sprayed by an oil mist out of the fuel pump "bleed hole"!
I don't know if all fuel pumps have this hole. (I don't have the original type fuel pump anymore with the screw-on filter) I think the purpose of the hole is to let the fuel run out onto the ground in case the diaphragm ruptures, instead of pumping the oil pan full of fuel.
Anyway whatever seals the crankcase from this hole failed and it was allowing the oil (assisted by excessive blow-by pressure) that lubes the pump arm on the cam eccentric in the timing cover to flow into the pump and out the hole. The hole is on the back side of the pump facing right at the oil filter and sending unit/extension.
I took the pump back to Checker Auto Parts and they exchanged it for free. No more mysterious oil leak.![]()
Hope this helps.
I'm sold. Called on fuel pump this afternoon. Will replace and post the results later on. As for the oil filter - it is new and I gave it the usually 3/4-1 full turn after engaging and I did apply oil to both sides of the rubber gasket before installing.
I did note in an earlier post that I have switch to Redline synthetic oil, but the amount of oil I lost the last time (covered parts of the fuel pump, oil filter, oil sending unit, power steering hoses, headers, and drive way) would probably happen with conventional or synthetic oil.
