I want to put my nozzel out of sight in my intake, but out of site is infront of my mass air meter. I don't think it's going to spray right on the meter pickup but it might get a little throught there?
... and operates because of ambient air passing through the elements to creat heat and change the resistance of the wires. Changing that temp with the chilly temps of N20 would vary the signal put out by the meter.
i have a tfs intake and it has a plug in the front of the intake - i have no idea what it was intended to be used for - so i got a threaded plug and ran my laughing gas nozzle through it. worked great. maybe your intake has something like that? what type of intake are you running??
I have the 351tfs it does have the same port but just wanted to be sneaky... That was the only place that was totaly out of sight. I hid my silnoids sp? in my inner fenders and all the wires also. I can always move it just a little just wondering if it would work.
what i would do is get an intake tube that would put your maf and air filter in the fender that way you can spray just behind the maf but still in the fender where no one will see it
spraying before the maf will cause the ecu to advance the timing a lot because its picking up very cold air but doesnt know that its n2o
