N41 cam
  • Thread starter Thread starter asecretfile
  • Start date Start date Feb 25, 2009
First Prev 2 of 2
dcurtis
688
Feb 27, 2009
#21
  • Feb 27, 2009
  • #21
We've used the lifter tools on 2 different engines with no problems, so far they are well worth the investment, and a real time saver.
Also is there a difference between the afm n41 and the afm n412 camshafts? If so what are they if anyone knows?
asecretfile
228
#22
  • Feb 27, 2009
  • #22
N-41
302 c.i.d. This cam is to be used with 1.6 R.R. Best cam for GT-40. Great with TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.73 to 4.30 gears. Good drivability down to 2100 rpm, lumpy idle, rpm range 2600-6200, works best with 89-93 EEC, needs 2800-3000 converter.
N-412
302 c.i.d. This cam is to be used with 1.6 R.R. Great with GT-40, TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.55 to 4.10 gears. Great drivability down to 1800 rpm, nice idle, rpm range 2300-6200, works best with 89-93 EEC, needs 2500-2700 converter.
First Prev 2 of 2
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
