  • 1994 - 1995 Specific Tech
Name this electrical component
  • Thread starter Thread starter mackey
  • Start date Start date Feb 18, 2004
M
mackey
1,284
Beverly, Massachusetts
Feb 18, 2004
  • Feb 18, 2004
What is this piece? Is there something that is supposed to go there? On the instrument panels only half the pieces light up. It is right next to the gas pedal on the right. Is something missing? The left side check engine/airbag light do not turn on. Is that normal? By the way its a just bought car. Good condition.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 18, 2004
  • Feb 18, 2004
:OT: Do you pass emmisions w/ your cats gutted? I wanted to do this when I dropped the h-pipe for the clutch install, but decided to wait for the x-pipe. Just curious.
The CEL/air bag lights should come on when you turn the key to the "acc" position, then turn off after a second or two. So if they don't, you DO have a problem.
Scott
P
PRO50SC
1,012
Olney, Maryland
Feb 18, 2004
  • Feb 18, 2004
That is the OBD2 connector for your computor. It's for scanning your ECM for codes.
bjl95mustang
1,495
Austin,TX
Feb 18, 2004
  • Feb 18, 2004
94-95 5.0 are obd-1 The ecm port is under the hood by the left strut tower. That is an obd-2 connector and it was used on the 94+v6 and 96+ 4.6. The connector under the dash is useless for our car's
M
mackey
1,284
Feb 18, 2004
  • Feb 18, 2004
Ok, Thanks. Yes the check engine lights do not come on when i start the car. I am thinking they need to be replaced and hopefully its just a burned out light and not a dealer trying to make a few bucks. Good thing we have laws in mass where i can bring it back if it does not pass emissions and they have to pay to fix it.
As for the gutted cats question. I have actually bought new cats so i switch them for the ones with something inside them for emissions. It isn't that hard actually just to remove them and replace them. The exhaust tone isn't as nice with gutted cats. I would stick with what you have.
M
mackey
1,284
Feb 18, 2004
  • Feb 18, 2004
What happens if it isn't the bulbs? what should i check after that? Where do those wires actually run to
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
