nasty shake at high speeds
  • Thread starter Thread starter 88Ryce_Eater
  • Start date Start date Sep 21, 2007
88Ryce_Eater
  • Sep 21, 2007
i was wondering if any one knew what this problem could be... every once in a while going high speeds, or even at high rpm's my 88 mustang gets shaky mainly in the stick and in the front end but not alot mainly in the stick any one know what that could be.??
Also how the hell do you find rotors for a 5 lug conversion kit??
91 HATCH
Banned
May 17, 2007
262
illinois
Sep 21, 2007
  • Sep 21, 2007
it could be rear control arm bushings
ttop88
42
indiana
Sep 21, 2007
  • Sep 21, 2007
It could be a lot of things. A bearing race going bad would do it. I have had the front wheel bearing and a inside rear carrier bearing do it to me. Took me forever to track it back to the carrier.
MarcMonteverde
66
S@c-ToWn
Sep 21, 2007
  • Sep 21, 2007
ya im havin the same problem!! onces i hit like 75 or so it shakes like crazy! i thought it might be that i needed new front tires! but wheel bearing sounds good to try an fix before i go spend like 2bills for some new front tires....
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 21, 2007
  • Sep 21, 2007
Yeah, could be a bad balance or no balance of wheels, bad wheel bearing, bad control arm bushings, bad steering shaft, bad inner and outer tie rods. Could be the driveshaft, bent axle shaft, bent wheel or two.
What I would do is start replacing stuff. I mean foxes are 14-20 years old and stuff wears out. Parts like inner and outer tie rods are inexpensive. Balancing wheels is inexpensive. I would start from there, and see where you are at.
ttop88
42
indiana
Sep 21, 2007
  • Sep 21, 2007
Don't forget u-joints.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
