nasty shake at high speeds
88Ryce_Eater
i was wondering if any one knew what this problem could be... every once in a while going high speeds, or even at high rpm's my 88 mustang gets shaky mainly in the stick and in the front end but not alot mainly in the stick any one know what that could be.??
Also how the hell do you find rotors for a 5 lug conversion kit??
It could be a lot of things. A bearing race going bad would do it. I have had the front wheel bearing and a inside rear carrier bearing do it to me. Took me forever to track it back to the carrier.
ya im havin the same problem!! onces i hit like 75 or so it shakes like crazy! i thought it might be that i needed new front tires! but wheel bearing sounds good to try an fix before i go spend like 2bills for some new front tires....
Yeah, could be a bad balance or no balance of wheels, bad wheel bearing, bad control arm bushings, bad steering shaft, bad inner and outer tie rods. Could be the driveshaft, bent axle shaft, bent wheel or two.
What I would do is start replacing stuff. I mean foxes are 14-20 years old and stuff wears out. Parts like inner and outer tie rods are inexpensive. Balancing wheels is inexpensive. I would start from there, and see where you are at.
