Nasty Whistling sound
TheRedBlur
15
seattle
I took my car out after having let it sit for a few weeks (bad weather). Now I'm getting a pretty nasty whistling sound, it sounds like a mix between a vacuum leak and a slipping serp. belt. So I got under the hood with some brake cleaner, hoping to find some external vacuum leak, nothing. Then I removed the serp. belt and started her up for a second, still the same sound. The engine has a high idle like it would with a vacuum leak, but when I shut the car off, the whistling goes away right as the engine stops, and becomes quieter as the rpms approach zero. Wouldn't a vacuum leak continue to whistle for a little bit after the engine stops turning? I also had some exhaust popping as I compression braked.
What do you guys think?
It's been a while since I've had to fix this thing, so my diagnosing is rusty.
If it is a vacuum leak at the engine it will stop as soon as the motor stops since there is no more vacuum. There are some devices that will hold vacuum but the motor will not.
I would take a close look at the PCV. It can be a source of a pretty big leak and it's pretty well hidden on an FI car.
i had a very high whistleing/shreiking sound comin from under the hood, freaked me out, though somethin was really f'd up. check'd the belt, intake, etc. just turned out that two header bolts were like a half turn loose. go figure, didn't sound anything like an exhaust leak.
hmm, that could explain it the sound, but not the high idle.
BTW: I've had this motor for 1.5 years and haven't done anything to it in the past 4 months. The whistling I'm talking about is a new sound that it hasn't made before.
