Need a how to on headgasket change
Chicago1
Hey guys brand new here my first post.My wife just blew the headgasket in her 96 auto convert and I was about to start the job here soon. I did a search and surprised I didn't see a how to. Could someone show me a link on step by step on how to get the heads off, what needs to come out of the heads and then put everything back together? Thank you much
Shant
I just did it on a 96 coupe with the 3.8. What a pain in the arse! You pretty much have to take everything off the engine until you are left with just the block connected to the transmission and motor mounts. Get a roll of duct tape and start numbering things like hoses, vacuum lines, electrical connectors as you disconnect them. It will make it much easier when you go to put it back together. The A/C pump can be unbolted from the mount and just laid to the side. Same with the P/S pump, but you'll need the P/S pump pulley puller which you can rent at AZ or most other parts stores. You will also need a few torque wrenches: NM, ft lbs, and in lbs. Buy or rent the tool to disconnect the fuel lines at the fuel rail, again about $10.00.
Not an impossible job, but like I said, it's a pain in the arse!
