Post #1
Welcome to 94-95 :SNSign:
Just some general things to think about when you use 1/4 mile stats to base
your expectations from
1) Driver ability has SO much to do with it :Word:
The less ability the more hp you need to make up for it
2) How good your car can sixty foot would be next to consider
The lower you can do this the less you need in the hp department
This can't be stressed enough
cause
Every tenth off the sixty will yield 1.5 to 2.0 tenths off on the big end
3) Your auto trans as it is now really hurts you when you wanna drag race
You can greatly improve things with a higher stall tc and shift kit
Again ... less hp needed if you are efficient here
Having said the above ... 2 & 3 will cost a good bit of money
Item 1 can make a big difference and will cost nothing but
track entry fee ... that is ... if you don't break something
I guess the point I'm trying to make is
You can obtain your goal with less hp than you suspect
IF
You get the most out of 1,2, & 3
I'm not too versed on auto trans combos but I'd say you could do it
with as little as 300 to 350 to the wheels
Now if you do a power adder and up the hp ......
you can slack off the above three ... well ... somewhat but not too much
as always ... more than one way to skin a cat
Grady
