- Jan 29, 2014
- 3
- 0
- 2
hi.. im new here hope im posting in the right place
ok so i'm gonna start ordering parts for my next project, gonna do it once and right the first time just need a little point in the right direction, so im gonna start the build with everything new from the ground up, going with a new stock block gonna push it .30 over, going with a scat 347 rotating assembly with dished pistons, H beam crank, pistons ect are forged..scat part # is pc98 if you need to look at the specs, wanna go with the afr 185 cc street/strip heads part # afr1492 for cam i would like to go with either a lunati or comp cams, so my question is would this combo work together? what cam with work with my bottom end set up? should i go 1.6 or 1.7 rollor rockers? this project is gonna be a 347 with a turbo in a 89 hatch also any ideas for an upper and lower for my planed combo? goona be fuel injected. any help from knowledgeable people would be great and any thing im missing please fill me in. thanks in advance
