need a little help with the wiring......
Phatt_daddy
219
Hytop, AL
On the '98 that I traded for, I started to really look the car over after I found out what was causing it to not start (btw thanks all who educated me on the pats) and I noticed that the idiot before me had cut the plug going to the fan off so that he could run the fan offof a toggle switch. appearently the fool didn't want to spend 15.00 on a new thermal fan switch or something. now for his constant hot he tried to tap into the wires going to the coil pack on the passengers side so not only do I have that to deal with I am missing the actual fan motor plug. none of the local jy's want to butcher a harness just for the plug so my question is does anyone know of where I can get the plug I need?
Also on a car without fogs but with the factory switch, does the factory also run the wires and have all hooked up or is that something I have to do if I want to add factory fogs?
thanks,
nate
