Need a suggestion on how to block off tstat to H20 pump bypass hose
mrf0rd
64
Kent, WA
Setup:
CSI electric H20 pump and March pulleys.
This setup eliminates the need for the short 90 degree bypass hose from the thermostat to the water pump.
I need to block off the 5/8 outlet from the thermostat. Has anyone done this or can anyone provide a recommendation on the best way to do this?
Thanks in advance.
Maybe try a rubber 5/8" cane tip or you can make something from a short piece of 5/8" hose and a piece of 5/8" barstock about 3/4" long and two hose clamps, probably safer than the cane tip. I used to blow out cane tips after about 2K miles with 9 psi of boost. They may even sell 5/8" hose barb plugs which would work great.
Good Luck, Don
