Need A4ld Transmission Line Help
tonyzz
Hello
I finally got the transmission seal changed but I want convert to rubber Trans line does anyone know where I can buy the fittings for the trans connections I believe it's a M12 x 1.25 1/2". My metal lines cracked from rusting. Thought of using stock metal fitting cut and the rubber hose clamped around the metal. Not sure if that would work. Any help would be great as I really want to get my 93 2.3 lx on the road again.
Thanks
Tony
Sent from my Nexus 7 using Tapatalk
Easiest is to go to a junkyard and get new lines and fittings.
Next is to get some steel line and unions at a parts store and install new sections. I do this on all my at cars to make it easy to get the line out of the way to change starters, pull the tranny, etc.
