Hi I'm getting ready to build an engine for my car and I would like to get some advice. This car will not be a drag car. It will be used to get groceries
and taken to the "Cruise in" on the week ends. Also it will be expected to run for long periods of time on the expressway. (Ohio to Tampa straight through). Do you think I would be better off building a 302-306 or a stroker? The max boost will be mild around 8 LB. I'm trying to figure out what compression ratio would be the best. 97% of the time it will be mild street driving. (But you gotta punch it now and then just for fun)
Also cam selection,, I don't think I need a huge thumper and I would like to keep some of my gas mileage. And I got power brakes need some vacuum.
So,,, 302-or stroker? compression ratio? Cam?
pump gas --I was thinking of Gt-40 or E7TE heads good heads for the buck?
looking for 5,600 to 6,000 RPM
