Alright, I just bought a used, low mile set of AFR 165's with 1.6 rr's. Based on my present setup (see sig. or my website), what else do I need to worry about?
I am pretty sure my stock valve covers will work if I modify the baffle in the passenger side one (right?).
Will the stock pushrods be fine, or do I need to step up to hardened ones (or do the AFR's require different sizes than stock)?
Felpro gaskets good enough, or do I need to spend the $80 or so for Cometic?
While I am at it, I was thinking about picking up a used cam. Any suggestions for these heads? I am considering having the Cobra intake port matched to the AFR's. Worth the expense?
I know that is a lot of questions, but figured I would lump it all in one post to save space. Thanks in advance for your input.
I like Go Daddy so far no issues...
