NEED ANSWER QUICK
i tried to zoom in a whole lot but no luck, you cant see much in the pics but no biggie, i have an idea of what you mean. And wow i've never seen an 03 even with a 100k but hey - at least you use for what its meant for = to be driven !!!
well i'll never know until the heads come off, but whats sux in my case is that im doing all of this on the street. Therefore i cant even pull the heads of to look at the valves since its snowing a whole lot here in NYC. Im waiting to strike a deal with a local shop for a 302 or 306 and only then if we realize its just valves, ill cancel the block swap n re-do the valves...
but is it possible that cyls 6 & 7 (in my case) would show only about 12psi on a compression test? while all the others are in the 170 range.
sure
yes,thats what a compression test tells,,not saying what is wrong,but that you have a leak(hole in piston/bent valve,rings,)any friends with garage??????I moved from N.J. 5yrs ago....my cobra only seen a little snow/salt , its 70 here now
im trying to get ahold of a couple of people.
One of my buddies has a garage but as you see in my sig, someone totaled his car so he has that in the garage and he is only half way into parting it out ....cant go there...but im working on something, this is my daily driver and i cant have it down for so long
