Need correct speedo gear
  • Thread starter Thread starter Treachery
  • Start date Start date Dec 19, 2004
T
Treachery
148
Dec 19, 2004
  • Dec 19, 2004
I recently had a Tremec 3550 TKO-II (.82 OD) installed. It seems that my speedometer is going slower than my actual speed.
I had 3.73 gears installed long ago and had the speedo gear changed to a 21 or 22 tooth. This made my speedometer go faster than my actual speed. But after the tranny swap, the speedometer speed is slower than my actual.
What would be the correct speedo gear.
Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 19, 2004
  • Dec 19, 2004
See http://www.hanlonmotorsports.com/t5speedo.asp
Or
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 2%-3% or less. The drawback is that it isn't cheap.
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
