Need Fuel Pump Relay Pin Info, I think I switched the pins around
StreetDreamsGT
449
New Jersey
Visit site
Hey guys, I just wanted to double check to see if I have the pins in the right spot on the relay, I pulled them out and I'm not sure if I switched them around or not. By the way the harness is from a 92 or 93 because the fuel pump relay is in the engine bay on the pass side. As it is right now, the red pin goes to 86 on the relay, 85 is light blue/orange, 87 is dark green/yellow, and 30 is tan/blk. Does that sound about right?
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
S 1995 Ford Mustang 3.8L V6 - Electrical Issues - Need Help! 1994 - 1995 Specific Tech 2
wbrockstar Help Needed To Identify Wiring Component On Hanger At Fuel Pump 1994 - 1995 Specific Tech 0
C Help needed 1994 - 1995 Specific Tech 4
C Help needed, good fuel pump but no pressure to rails 1996 - 2004 SN95 Mustang -General/Talk- 1
L Need Help At A Loss... Fuel Pump Won't Turn On Fox 5.0 Mustang Tech 7
R Need Help Diagnosing T Rex Fuel Pump Power Issue SVT Tech Forum 0
M Need Help On Fuel Pump Set Up SN95 4.6L Mustang Tech 3
C Fuel Need Some Quick Help With A Fuel Pump SN95 4.6L Mustang Tech 26
jaketuff Need Some Help... Car Cranks, Sparks, Fuel Pump On... Won't Start! Fox 5.0 Mustang Tech 8
1 Electrical Need help please! No spark, Fuel pump not priming, and a mystery wire. Fox 5.0 Mustang Tech 36
gtthomas Fuel Vortech v2 install. need fuel pump help BADLY SN95 4.6L Mustang Tech 8
Rejekt Svt Focus Fuel Pump - Need Part # SN95 4.6L Mustang Tech 2
L Fuel 1994 Gt Fuel Pump Wiring Help Needed 1994 - 1995 Specific Tech 8
musclemustangcb I'm installing dual super car fuel pumps. Do I need to change/add a fpdm??? SN95 4.6L Mustang Tech 2
musclemustangcb Installing a on3 dual/triple fuel hat with dual super car pumps. What else do I need?.. SN95 4.6L Mustang Tech 5
1bad67sbf need some help with the fuel pump power feed Fox 5.0 Mustang Tech 20
N need some help with the fuel pump. please Fox 5.0 Mustang Tech 2
S How much clearance do you need between fuel pump eccentric and timing cover? Fox 5.0 Mustang Tech 6
trailblazr81 Need step by step to determine if fuel pump bad SN95 4.6L Mustang Tech 4
3ponyshow Need some recommendations on a fuel pump SN95 4.6L Mustang Tech 12
stanGRR fuel pressure r need upgrade fuel pump?? Fox 5.0 Mustang Tech 4
sneaky98gt NEED HELP FAST! Are V6 and GT Fuel Tanks/Pump Assemblies the Same? SN95 4.6L Mustang Tech 4
Bill Cool Need to borrow known working 87-93 fuel pump relay in CT Regional Forums and Event Information 0
Z Help! Need a fuel pump electrical connector Fox 5.0 Mustang Tech 6
V Higher flow fuel pump...need tune? SN95 4.6L Mustang Tech 5
PR_wingman MAF conversion fuel pump issue NEED HELP Fox 5.0 Mustang Tech 4
R Fuel pump issues, need help! Fox 5.0 Mustang Tech 3
N Need help with fuel pump and lines Fox 5.0 Mustang Tech 1
9 need help!! fuel pump not turning on Fox 5.0 Mustang Tech 1
custom00gt need help with a 00 gt fuel pump SN95 4.6L Mustang Tech 2
M Fuel pump issues need help got stranded twice in one night SVT Tech Forum 0
95 Black Mamba need help getting power to fuel pump 1994 - 1995 Specific Tech 6
russ1979 need help with fuel pump install Fox 5.0 Mustang Tech 3
N Fuel Pump not working. need help 98 GT Mustang SN95 4.6L Mustang Tech 21
hotcobra03 Fuel pump help needed SVT Tech Forum 3
Aaron Fuel Pump Help Needed Fox 5.0 Mustang Tech 8
P do i need a new fuel pump? SN95 4.6L Mustang Tech 3
8 help fuel pump relay need to get to work in the morning!!!!! Fox 5.0 Mustang Tech 18
Swede958 Fuel pump (and/or relay) issue... need help fast Fox 5.0 Mustang Tech 0
dcurtis Need a Fuel Pump Sending Unit 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
F 255 Fuel Pump Do I Realy Need A Adjustable Fuel Pressure Regulater??!! 1994 - 1995 Specific Tech 14
M fuel pump went out, need some help SN95 4.6L Mustang Tech 14
B need to find socal dealer for fuel pump tsb 2005 - 2009 Specific Tech 0
Yellow302 Fuel pump line only reading 1.7V... need help 1994 - 1995 Specific Tech 2
Yellow302 Fuel pump died, need 255 pump cheap 1994 - 1995 Specific Tech 3
hotmustang331 What do I need to install the second fuel pump? SN95 4.6L Mustang Tech 12
H Help... need a new fuel pump, which one? Fox 5.0 Mustang Tech 14
RsStanG1987 Fuel pump part# needed asap Fox 5.0 Mustang Tech 2
STROKED_LX Need help with Fuel pump realated. 2.3L (N/A & Turbo) Tech 3
dark_cobra_01 89-LX Fuel pump keeps running with Key out of Ignition... Need Help Fox 5.0 Mustang Tech 4
