Need Fuse Help
BlackenedSVT
1,841
New Jersey
Just got my SCT X-Cal2 :D
Its asking to unplug to the Fuel Pump and Electric Fan Fuses. So i was wondering where these were. Under the steering wheel or under the hood, and does anyone have a quick picture of these specific fuses? I'm feelin lazy :)
Anyone know where the Cigarette Lighter Fuse is by chance either? My lighter doesn't work and i want to check it...
Kilgore Trout said:
All those fuses are in the fuse block, for more information please refer to your owner's manual.
:rlaugh: Spoken like a true customer service representitive or somethin :)
Bah! I guess you're going to make me do some effort and work by walking out to my car and READING. :fuss:
well it's better than spending $200 on a fan problem to find.....
SteedaGTJ22 said:
What does that mean, and why would u say i would be throwing that code?
And it hasn't thrown any engine codes yet, why would i have that code?
didn't say it was going to, just likely that it would :)
the reason being is if you took the fuse out for the fuel pump & started it, that means not enough fuel was getting to the engine. it started due to the system still being pressurized & having excess still in the lines. this would mean there was not enough enough fuel in the rails (where the sensor is), thus kicking the code :nice:
Well i've gone to vermont and back this weekend and i dont have a problem with a code :shrug:
Were you implying that IF that code came up the sensor is BAD? Or just malfunctioning or somethin. I dont think this code will appear after considering how long i've driven it now
nah, it was more of a warning that it could happen since you tried to start it that way. if no light came on you're good to go :nice:
Yeah i only started it and stopped it. I figured excess pressur ein the lines is what cuased it to start. But even at tech school we would always pull the fuel pump fuse to do a compression test or something liek taht ya know. and cranking it while its getting no gas. Must just be a ford thing to have that sensor fault code then? :shrug:
