Hey Dan
I got some general thoughts about oem iron heads.
Not fair to compare them to TFS, Edels, AFR or other heads that have been the recipient of newer technology.
Its all about how the newer heads are made which makes them so much more efficient than the oem heads.
The fact that the newer heads are Aluminum does not have a lot to do with what I'm trying to get across here as well.
Bottom line is this thought, I guess ................
Newer heads are more efficient thus they flow more air
Just plain old horse sense tells me cams like Ford alphabet or others from the days of old when there were no or very little choices in heads other than oem need to be looked upon differently than cams of these days which have also benefitted from newer technology.
Back in the older days it was a common practice to use the cam to crutch or make up for the short commings of port design with the older oem iron heads.
Now here is where I'm trying to go with a thought and I wonder if consideration of that thought is even worthy
Since you are gonna be using some ported oem heads ......
Would the TFS cam which is made for a totally different kind of head be all that wise of choice with your combo
Just thinking out loud
and
Considering I used a hired gun to kill my cam issues
I don't claim to know a great deal about cams other than general info.
If you can supply a few examples in the way of dyno pulls with the combo you are considering, I may be able to do a comparison to a different combo which might give some insite or reference point ... if you will.
Grady
