Torque Specs
always torque bolts in three equal increments
Bolts or Parts Lube or Sealer Torque to:
Main Caps Engine Oil 105 ft-lbs.
Connecting Rod Bolts
Engine Oil 45 ft-lbs.
Cylinder Heads 351W
Engine oil (blind holes)
Sealant (water jackets)
85 ft-lbs.
Cylinder Heads 302 HO
Shorter Bolts
Longer Bolts
Engine Oil (blind holes)
75 ft-lbs.
85 ft-lbs.
Rocker Arms Engine Oil 20 ft-lbs.
Oil Pump Engine Oil 25 ft-lbs.
Oil Pump Pick-up Thread Locker 20 ft-lbs.
Oil Pan Engine Oil 15 ft-lbs.
Camshaft Thrust Plate Thread Locker 10 ft-lbs.
Cam Bolt (upper gear) Thread Locker 40 ft-lbs.
Front Cover Engine Oil 25 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 25 ft-lbs.
Valve Cover Engine Oil 10 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 85 ft-lbs.
Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt
(Harmonic Damper)
Thread Locker 90 ft-lbs.
Bellhousing
(Transmission to Block)
http://boxwrench.net/specs/ford_302_351W.htm
