Need Help !!! 2004 Gt No Brake Lights
Blake1770
I have a 2004 mustang gt I have no brake lights. I have power every where I have also changed fuses,bulbs,brake switch and also the blinker switch, I am lost can anyone plz help.
Welcome to Stangnet.
I moved your thread into the '96-04' section and edited your title . This way more members will see your thread,and drop in with ideas/advice.
When you say you have power everywhere-does that include at the brake light switch? Also have you checked the ground wires?
The grounds are
The grounds were showing good I have power in and out of the brake light switch.
CONFIRM +12 volts at the high mounted 3rd brake light using a KNOWN good ground.
IF no voltage at the 3rd brake light but confirmed voltage at the brake pedal switch the problem MUST be a wiring fault between the two locations.
Before chasing a wiring fault I strongly urge you to double check your work or a wild goose chase could be in your future.
Reactions: RaggedGT
Start in the drivers side kick panel. There are a lot of connectors in there that run from the front harness to the rear of the car. I've seen them get dirty, broken or pinched over the years and cause odd problems.
