need help a.s.a.p
keith6891
39
i just got a edelbrock rpm intake i would like to get a t.b but i dont know what kind i have found a power t.b who makes that? bbk, mac, propessional products, accufab, and edelbrock, i just dont know what would be the best :bang: for the buck all of this i found on ebay so can someone help me with this thanks... LOOK DOWN
if the accufab is goin for a good price get that one. ive got a BBK and dont have any complaints about it. but accufab makes nice pieces. if youve got a stock engine...just get a 65mm because you dont need anything bigger until you get lots of power
MORE
I DO HAVE A SET OF GT40HEADS BUT I DONT KNOW WHAT TO GET DONE TO THEM COULD I GET A 75MMTB I HAVE A 75 MM MASS AIR 24LBS INJ BUT NONE OF IT IS ON THE CAR YET..
you can just bolt them right on if you want. or you can get the port and polished and make some really good numbers. PM Thumper460 and see what he says..or check out his website www.thumperoforangepark.com , another thing you might want to consider is a cam if youre putting heads on, and an intake. you can just get the lower intake ported by TMoss. with all of that you will make some nice power numbers
ps. a 75 mm will be too big unless you are planning to put a blower on it
you can put all new internals in it and build yourself a good strong motor. get it bored out and throw a 331 stroker kit in it. get a main girdle system from dss...lots of things you do to it. if i were you i would put those heads on it, get a nice cam and intake. build up that motor to how you want it and throw it in the coupe. that way you dont have to keep tearing your motor apart if its your daily driver. you can just put pieces on the block you have when you get them
IS THERE A BOOK THAT CAN HELP ME OR SOMEONE ON HERE THAT CAN NEVER DID ANYTHING LIKE THIS IAM NO DUMASS BUT I DO NOT WANT TO ***. THIS UP I KNOW I HAVE JUST ABOUT ALL OF THE UPPER STUFF THAT NO BIG DEAL BUT THE BOTTOM CAM RINGS PISTONS OR COULD I GET I VERY GOOD KIT
get a haynes manual and a chiltons manual. they will explain everything. yeah you can get kits that come with everything you need from jegs, summit, dss, trick flow, just about anywhere. also, there are lots of very knowlegeable people on here that can help you with any problems you might run into. if you have specific questions you could PM Thumper460, Tmoss, jrichker, v8only, hissin50....just some of the guys who ive noticed really know their stuff. good luck with it man, and let us know what you plan to do. also, you can probably find out which heads/intake/cam are best for what you want to do in the search function at the top of the screen.
