  • SN95 4.6L Mustang Tech
Need Help Adjusting Odometer. Not The Gauge That Came With The Car.
  • Thread starter Thread starter StangVertGT
  • Start date Start date Apr 25, 2013
StangVertGT
199
Apr 25, 2013
  • Apr 25, 2013
So as most of you may know, my gauge is not the original gauge cluster that came with the car. I found out that it was taken out of a 2001 Mustang at a junkyard with the wrong mileage. Would this cause any problems for my car seeing I have a 2002 Mustang GT?
Is there anything I need to have done to the cluster, do I need to buy a 2002 gauge cluster for the car? While I'm dealing with the cluster, where in LA can I go to have the milage changed to the right mileage and about how much would it cost?
Thanks for all your help!
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
  • Apr 26, 2013
What's the problem with it? Is there something that's not working correctly?
StangVertGT
199
Apr 26, 2013
  • Apr 26, 2013
Everything works fine. There is one issue, probably minor... When you turn the light knob to the right, about half way it will start to dim and then if you keep turning it, it will blink and disappear for a minute and then go bright again.
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
  • Apr 26, 2013
I might look at replacing that switch then. Otherwise, press on with pride. You can keep track of the mileage manually (old oldometer + whatever you put on this odometer). You can also take it apart and rotate the OD dial to match you old one. I recently saw a thread about that very thing, here on Stangnet.
StangVertGT
199
Apr 26, 2013
  • Apr 26, 2013
Awesome! Thanks man
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
  • Apr 26, 2013
Here's a link for you to go through to help setting the OD:
http://www.stangnet.com/mustang-forums/threads/pictorial-guide-to-odometer-gear-replacement.605742/
I'm pretty sure you have to pull the same gear that's talked about in the thread in order to roll the tumblers around. Jinx should be able to help you out.
StangVertGT
199
Apr 26, 2013
  • Apr 26, 2013
I'll check it out. Thanks for posting it for me!
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
  • Apr 26, 2013
Werd... Jinx will get an alert when he logs on so he will find your post.
StangVertGT
199
Apr 26, 2013
  • Apr 26, 2013
How do I change my mileage back to the right mileage?
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
#10
  • Apr 26, 2013
  • #10
I'll let Jinx explain it when he comes on as I've never done it on anything other than a Fox.
Also... I'll update your thread title so that others that may know can come in and help.
StangVertGT
199
Apr 26, 2013
#11
  • Apr 26, 2013
  • #11
Great! Thanks man!
StangVertGT
199
Apr 26, 2013
#12
  • Apr 26, 2013
  • #12
Some place here in LA wanted to charge me $200 to change the mileage back to the right mileage.
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Apr 26, 2013
#13
  • Apr 26, 2013
  • #13
Sounds about right... It's a couple hours of labor but you can do it yourself.
StangVertGT
199
Apr 26, 2013
#14
  • Apr 26, 2013
  • #14
Good to know. I thought he wast hustling me. I like to do my own work on my car if I can, I don't care how long it takes.
txredgt
1,343
33
69
Apr 26, 2013
#15
  • Apr 26, 2013
  • #15
Can't do what jynx did in his thread. Jynx's car has the old odometer an trip while the 99+ cars are digital. I got a feeling you may be stuck spending money if to really want it fixed.
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Apr 26, 2013
#16
  • Apr 26, 2013
  • #16
Sorry about being late to the party. I did remove and replace the gears for the odometer in a '95, but never rolled back or rolled forward the mileage. Did not have to.
Since the newer clusters are digital, I'm guessing you have to have a programmer of sorts to reset it. I'm not even sure if the newer clusters are completely digital, or if they are mechanical with a digital readout??
sorry I could not be of more help.
StangVertGT
199
Apr 27, 2013
#17
  • Apr 27, 2013
  • #17
So basically I'll have no choice but to pay that $200 to fix the mileage. Seems pretty steep but it is what it is. Thanks guys
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
T
2003 GT cluster issue
  • Timothys gourmet
  • Aug 26, 2025
SN95 4.6L Mustang Tech Aug 28, 2025
Mustang5L5
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
